wont start up properly
My iMac wont start up properly just a small file comes in the middle of the screen with a head in it
Bu iyi bir soru mu?
Bu iyi bir soru mu?
your Mac is likely having a problem either finding your startup disk or the system software. it may be a hardware problem with your disk drive, or just corrupted OS files on the disk.
try booting from your OS install disc - hold the C key down with disc inserted while you reboot.
then after booting, go to Disk Utility (in the Utilities menu) and try repairing your disk volume. if repair is successful then reboot and see if everything is ok. or you may need to try re-installing the OS
if you can't even mount or see your internal hard drive in Disk Utility, then it's probably a defective hard drive.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 1,903
2 Comments
Could that be a question mark instead of head?
mayer tarafından
yes a question mark sorry
angie tarafından
