Ana içeriğe geç
Reflection across top of screen
I’ve attached a photo of what is happening, any ideas?
Update (11/04/23)
Attached
Update (12/19/23)
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
6 Yorum
Hi @hiramsaunders,
What is the model number of the TV?
Do you also see this problem when normal video is shown?
Is the display darker or discoloured in that area?
tarafından
UE70TU7100KXXU
I would t say darker more lighter, it reflects what is below it. It’s not as noticeable in darker images.
I’ve tried resetting, it’s on any device too, normal tv, sky box. Etc
tarafından
@hiramsaunders
To me it seems to be a problem with the driver boards in the LCD panel given that it is a horizontal line so to speak but I'm not sure.
Perhaps @oldturkey03 may have a better idea.
We're in different time zones so hang in there for 12+ hours for him to respond.
He'll tag you if he answers so you will be notified
Cheers
tarafından
@hiramsaunders any chance you can post a different picture, maybe a lighter background etc. This could be a ribbon cable issue or (worst case scenario) a panel issue.
tarafından
[image|3121188][image|3121186][image|3121187][image|3121190][image|3121189]
Attached
tarafından
1 tane daha yorum göster
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@hiramsaunders that looks like a Gate Driver failure. Check the driver boards (long, skinny boards) that are attached to the panel via some flat ribbon cables. Post some pictures of those if you can. It might be possible to determine if this is a board or a COF error. Not en easy fix either way but at least we should try to narrow it down to what needs to get done.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
I’ve added photos in the above. Thanks
tarafından
Yorum Ekle
Yanıtını ekle
Hiram Saunders sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 184
