Ana içeriğe geç
Latitude 3480, Dell tarafından üretilen 14 inçlik bir dizüstü bilgisayardır. 3480 modeli, geliştirilmiş veri koruması ile küçük ve büyümekte olan işletmelere yönelik pazarlanmıştır.
Alert TPM device is not detected
Hello everyone
When I turn on my laptop i see this message " Alert TPM device is not detected"
Thank you so much
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Does it allow you to bypass the error? This may not be anything that will affect your ability to use the computer. The TPM or Trusted Platform module isn’t inherently necessary for functionality (unless you’re running Windows 11) but it does store secure data like a Bitlocker Key if your drive is encrypted.
So strictly speaking you don’t need it. That doesn’t mean your computer might not throw a hissy fit if it expects there to be one, but it isn’t detected.
Your BIOS might just need to be updated, TPM may have even been inadvertently disabled in BIOS. If it will let you bypass the error, I would check dell’s support site for an updated version of BIOS
Bu yanıt yardımcı oldu mu?
Puan 3
7 Yorum:
Thank you for the response.
Yes, the computer is working well, but recently, I installed Windows 11, and I had to make some adjustments in the BIOS because my device doesn't support Windows 11. Two days ago, I updated the BIOS to the latest version from the official website.
Is there a solution to hide this message because it's annoying?
I am a technician and a computer hardware engineer, and I know it requires reprogramming the BIOS file, but I wanted to know if there is another, better solution.
Thank you for your help once again.
tarafından
@kingman28622 Where do you get the alert? Is it within Windows? Or is it a pre-boot warning?
tarafından
@flannelist in pre-boot warning
tarafından
@kingman28622 You may be able to disable those through BIOS. I have seen before in Dells that you can turn those off in some cases (usually for charger errors) but it may apply for something like this as well. I would check BIOS settings to see if there is a way to disable this sort of warning.
tarafından
@flannelist "The problem is that there are no options related to TPM."
tarafından
2 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
King Man sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 702
