Ana içeriğe geç
Ladestation zur Xiaomi Roborock S5 - Serie
Roborock S5 not charging - Error 13
Xiaomi Roborock
Hi !
I have the problem Error 13 . In the robot changed the P185 fuse.
I have 2 charger. In same chaerger changed the condensator . Not some cheap, im using Nichicon 450v 68uF.
One charger working good, all ok, but the another not.
On the bad charger measuring 4,2v , if charged 20v.
Sometimes the robot starts charging, but after a few days it doesn't. Then I put the charger aside and after a few it's good again for a while.
In the bad charger changed again another Nichicon condenstor --- not working
Changed the ISA07N65A Mosfet ---- not working
what can i do? Have any idea ? Thanks
Update (11/14/23)
Hi @hainzy !
My question its moved so, i try answear here.
"the Parts your replaced where faulty, or did you replace them without checking?
when you are already replacing parts you could also try to replace these:
- Mosfet B09N03 (EMB09N03H) or B09A03 (EMB09A03HP) - depending on the version
- Controller MAX8731A (MAX8731AETI+) or BQ24773 (ref BQ24773RUYT) - depending on the version
or you replace the whole board of the Robot, or the charger.
That would probably be easier...
But you did already check the battery, right? "
The capacitator its fault , the mosfet i think not, but i have one new so i chang it.
The battery its good, with another charger allworking ok.
If i can buy, i will try change the Mosfet B09N03 and the Controller MAX8731A. Thanks,
Bu iyi bir soru mu?
Puan 1
2 Yorum
@sygnus what exact model is your RoboRock?
tarafından
Roborock S5. The simple S5 , not the max.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi @sygnus,
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
I had a similar problem and it turned out that it was not an electronics problem but a mechanical one. Look carefully at the contacts in the charging station. In my case, one of them was worn out and rarely made contact. I bent the metal contact a bit and the problem was solved.
Robert
Puan 1
1 Yorum:
In the meantime, it turns out that the crappy Chinese P185 that was replaced earlier was again at fault.
I just bought a Ruville product, it works with it.
tarafından
Yorum Ekle
Yanıtını ekle
Sygnus sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 40
Son 30 gün: 165
Her zaman: 2,985
