Ana içeriğe geç
2. nesil Apple Silikon (M2 çip) ve 13,3" Retina ekrana sahip MacBook Pro 13" için onarım rehberleri ve talimatları. Model A2338. İlk olarak 15 Temmuz 2022'de, WWDC 2022'de MacBook Air M2 ile birlikte piyasaya sürüldü.
MacBook Keyboard Spill Not Working
Macbook was on when around half a cup of saline solution was spilled on it. Tried to wipe it off right away and the laptop stayed on. Keyboard wasn’t working so the laptop was still on when I flipped the laptop upside down. The keyboard eventually started working so I turned the laptop off but still kept the laptop upside down. Used a blowdrier to dry it for around ten minutes. Now the display works perfectly fine but the keyboard is non functional. Touch bar doesn’t turn on, keys can’t type, and trackpad doesn’t work. Apple store said repair would be $1000 but I feel like I could fix it myself for less. How should I go about fixing this? Thanks!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Salt water corrodes electrical circuits! Hopefully it stopped at the keyboard/touchpad.
You'll need to either replace the full uppercase assembly (which I strongly recommend) or locate the raw keyboard and fight through the ton of plastic rivets! Most people end up distorting the Uppercase shell in the process and so far I haven't seen any M2 keyboards offered, I'm not sure if the M1 is a direct fit or not.
Then you have the Touchpad to deal with as well if it was damaged too.
Here's the Apple Repair manual 2022 13" M2 system Review Page 158 as well as Page 8 which offers the P/N info.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Lexie sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 15
Her zaman: 299
