Ana içeriğe geç
Laptop will not charge with Lenovo supplied power adapter.
Laptop will not charge with Lenovo power adapter or any other USB-C power source I have tried. When plugged into power the light adjacent to the power port flashes (amber color) every 2-3 seconds. Laptop worked fine yesterday. I suspect a bad power port on the laptop. Is there any way to confirm this?
SOLVED: I opened the back and removed the battery. It still would not boot when plugged into the power adapter, I reconnected the battery, replaced the back and the problem was fixed. It's charging normally now.
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
The fix above did not last very long and it eventually stopped charging again. After some back and forth with Lenovo tech support it was decided that I needed a new motherboard. I sent it back to them and had it repaired. Now the laptop charges normally but I have a new problem. It is often reluctant to awake from sleep mode. I have disabled all sleep settings and continue to have this problem. But this is a topic for a new post...
tarafından
Yorum Ekle
Yanıtını ekle
David Pinals sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 31
Her zaman: 349
