Ana içeriğe geç
4 Kasım 2017'de satışa sunulmuştur. Model A1865, A1901. GSM ya da CDMA olarak 64 ya da 256 GB kapasitelerinde, Gümüş ya da Uzay Grisi renklerinde satılır. ("iPhone 10" olarak da telaffuz edilir.)
Bootloop after battery replacement
Hello, I recently replaced my battery and after doing so my phone became stuck in a bootloop. I tried restoring via iTunes but it gave error code 9. I looked at other posts on this forum and assume I broke a resistor I would like to try resoldering it but I can't find the damage. It also keeps popping out and another flex cable for my atenna (I think) also keeps popping out. Pictures added below.
Battery:
Wifi/BT:
Any help would be much appreciated.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Hello, could try to disconnect your earspeaker flex cable and try reboot the phone? It is very common and easy to damage the proximity sensor that is on that and cause boot loop.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Hi, unfortunately that isn't the problem the cable from my earspeaker isn't connected since I replaced the screen but didn't put over the speaker yet.
Thanks for your reply
tarafından
Yorum Ekle
I had a similar issue after a battery replacement once. The bootloop can be frustrating. In my case, it turned out to be a loose connection inside. I had to double-check all the cables and make sure they were securely attached. Also, try cleaning the connectors with some isopropyl alcohol if you can.
Puan 0
1 Yorum:
Do you remember where the loose connection was? Battery flex? I will try alcohol asap. Thank you for your help.
tarafından
Yorum Ekle
Yanıtını ekle
Bermt sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 17
Her zaman: 336
