Some Keys Not Working
(Sorry my english is not good)Some of The Keys are not working Properly after cleaning The Keyboard It happened while i was playing some games it eventually stopped working
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Depends on what switches you have. If the switches let light through to work, then something might be blocking it, If they arent then something else might be wrong. I would suggest taking it apart if you have some tools (screw drivers). Look to see if anything is disconnected, if its not then take the PCB and switches out and then put them back together. That should work but it's not guaranteed; If it doesn't then you should just replace the keyboard. I hope I was helpful!
Bu yanıt yardımcı oldu mu?
I had the same problem so I took it apart. The wires going to the RGB lights had broken, which I might be able to solder. But now I cannot put it back together, even if I try to put it back together somehow it refuses to work at all. I really need a guide to put it back
Son 24 Saat: 6
Son 7 gün: 11
Son 30 gün: 46
Her zaman: 1,339
