Ana içeriğe geç
Repair and disassembly information for the first generation of Apple's high-end wireless earbuds. Released in October 2019. Identified by model numbers A2084 (left earbud), A2083 (right earbud), and A2190 (charging case).
Airpods not charging in the case
So my airpods are not charging in the case but they still connect to my phone and even if i charge the case i doesn't charge the airpods. They've been discharged for over a week and i dont know what to do. Does someone have a solution.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
But the case seems like it's charging or is acting charged?
If neither of them are charging this might be a firmware issue. Apple's firmware update solution is sort of silly. The process is effectively:
  1. Put Airpods in the case.
  2. Charge the case. Make sure the lid is closed.
  3. Leave them on the charger near a paired device. Apple suggests twenty minutes, but if you can spare the time leave it for an hour.
You can also try resetting them. This will return them to factory settings.
  2. Close the lid and wait thirty full seconds.
  3. Open the lid then press and hold the button on the case for fifteen seconds or so.
  4. The light will blink amber, then white if you are successful.
I would also give the case a good inspection. See if there is anything stuck in the bottom of the case. Otherwise, a replacement case would be your best bet.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
I would get a replacement case from apple
Puan 0
Yorum Ekle
Yanıtını ekle
Gabriel Caisse sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 254
