Ana içeriğe geç
Infinix Mobile is a Chinese entry level smartphone company founded in 2013.
Why is my phone shutting down automatically?
my phone shutting down automatically with out my permission. after a few minutes of using it i get it switched of . even it shutted down it self morethan 10 times a day?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
2 Yorum:
Yeah i believe that they will help me to submitt my problem thanks for respond me
tarafından
Switch is forty
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
@akiyagetachew this could be a software issue. Try a reset of your software. Remember to make sure that all of your files are backed up etc. Also, check if this happens in safe mode as well or if it stays on. WE need to know the exact model of your Infinix to help you with the Safe mode. Generally you can get into safe mode by following the steps from this site. If none of this works, I would replace the battery. Once you replace the battery, make sure that your charging port works.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
I also have the same problem, kind of. my phone would just randomly shutdown after a few minutes. i don't know about the original poster, but mine was infinix note 12 vip with the model number x672. I've tried resetting the phone and even hard resetting it but the problem still continues. and as of the time writing this, my phone is unable to be turned on. even on full charge, the phone would fail to turn on, and when it turned off the battery would become empty. my battery should be fine because i've always using the stock charger and never used any third party charging brick and usb. my speculation might be there is something wrong with the power ic, but i'm not sure, because i myself has not get it checked to any real technician
tarafından
Yorum Ekle
Please my infinix x6525 shutdown automatically please can you help me fixed it
Puan 0
Yorum Ekle
Yanıtını ekle
akiya getachew sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 15
Son 30 gün: 107
Her zaman: 1,360
