Ana içeriğe geç
Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Soru Tümünü görüntüle
Why my touch at the bottom level is not working?
My iphone's touch at the bottom lineup is not working.
I mean, the bottom level..Else is workin fine.. Even i can slide when cal is coming.
But cant click on the "Answer" or "Decline" buttons.
help please/
I did restore, bt not working..
Help
Bu iyi bir soru mu?
Puan 0
2 Yorum
Same here But im not confident to take off the screen as i might damage my phone more
tarafından
Hollzkid, you may have to get it fixed by one of the numerous phone repair centers;-)
tarafından
Yorum Ekle
5 Cevap
Filtre ölçütü:
Seçilen Çözüm
sam, it is my experience that if a certain region of the digitizer (touch screen) does not work, it needs to be replaced to be fixed. This is due to broken contacts within the digitizer. Here are some directions that you might find helpful, good luck.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Hi Sam,
By the sound of it, the digitizer cable may have become dislodged from its connector on the board. My suggestion is, if you are confident to do so, pop the screen up on your phone, and gently push on connector number 2 to push it back into place, try using this video guide to get your screen off, all you'll need is a Phillips cross-head screwdriver, and a small suction cup. Hopefully this should solve your problem, and have your phone fully operational again.
Puan 0
Yorum Ekle
hey, I have the same problem, only that that part actually works if I flip the screen in landscape mode, and certain apps like music player get the touch commands, even if laggy. Restoring didn't work. What do yau think?
Puan 0
Yorum Ekle
Use an android app to fix that
Puan 0
Yorum Ekle
Sounds like my problem, except now I can’t even unlock my phone with the passcode because of this. I need to replace the battery, do I need to replace the screen too? I need this phone. It was working fine earlier.
Puan 0
Yorum Ekle
Yanıtını ekle
sam sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 7
Her zaman: 45,973
