Ana içeriğe geç
Released in 2020, the Mi 10 Pro is Xiaomi's 2020 flagship phone that competes with the Oppo Find X2, Huawei P40 Pro, and Samsung S20 family.
over the last week charging speed got slow until it no longers charge
hello, over the last week my xiamo mi 10 started charging slowly
sometimes it would charge sometimes it would be barely enough to keep the % of the battery the same until today, it stopped charging its been stuck at 1% for 30 minutes,
before it stopped charging i checked battery health with ampere and it said good
i was thinling of replacing the charging port and the battery since the smartphone is 3 years old (might as well change the battery since im opening it)
thanks
Aggiorna (11/27/23)
forgot to mention that charging battery has a voltage of 3,3, it should ne 4,4 right?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
1 Yorum
Any luck fixing this problem?
I only changed The charging port assembly to NO avail.
i know that The battery was in good condition about 1 month before it started to break down.
NO its like a brick...
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@ayo53249 "forgot to mention that charging battery has a voltage of 3,3, it should ne 4,4 right" around 4.4V would be about correct. Replacing the battery and the charging port should resolve this. Since iFixit does not yet have a guide for this, Use something like this video to work on your phone.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
You can also check for a USB to type C charger cable, maybe from the time makes inside some fail and if short circuit then empties the battery and won't charge.
It's also, the cheapest item for you to thing first for check, before you go to the solution of changing the USB type C charge plug of the phone.
Puan 0
Yorum Ekle
Yanıtını ekle
ayo sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 59
Her zaman: 921
