Ana içeriğe geç
Acer Aspire V5-471, öğrenciler ve günlük kullanıcılar için tasarlanmış 14 inçlik, bütçe dostu bir dizüstü bilgisayardır. Intel Core işlemciler ve tümleşik Intel HD grafik birimi kullanır. Onarımlar, sorun giderme, parça değişimleri ve teknik özellikler için destek mevcuttur. Bu cihazın bilinen diğer model isimleri arasında V5-471-6614 ve V5-471-6888 bulunmaktadır.
change hdd to ssd problem
My Acer V5-471 laptop: I replaced the HDD with an SSD, but the laptop didn't work at all. The power button shows a blinking blue light quickly, and the laptop doesn't turn on. When I reverted to the HDD, it worked normally. Is there a solution or explanation for this issue?"
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@mustafameddah do you have an OS on the SSD?Since you did not give us a lot of detail, I'd check on this. It is possible that your computer does not detect an OS and treats the POST as a failed drive. You will need to set your BIOS to boot from something like a bootable USB drive and install an OS to the SSD
Bu yanıt yardımcı oldu mu?
Puan 1
3 Yorum:
the ssd is new there is no os on it and it is not partitioned yet
the problem is that the pc doesn't turned on at all now bios shows up or nothing when it press the power button a blue light on the power starts blinking very fast that's it. i cant get to the bios or nothing else the screen black and the fans doesn't start at all
tarafından
@mustafameddah but all that works again when you reinstall your HDD? If so, you do know that the issue is with the SSD.
tarafından
@oldturkey03 yes because it's new and still not identify as mbr or gpt and still not partitioned yet i took the ssd and palced it on my desktop pc make it mbr split it to one part of 100 gb installed windows 10 and took it off and put the ssd again on the pc acer that it didn't work and it started normally thank you for the reply back
tarafından
Yorum Ekle
Yanıtını ekle
mustafa meddah sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 45
Her zaman: 480
