Why is my engine cooling water reduce rapidly?
why is my engine cooling water reduce rapidly?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
@abelsitotaw check for a leak on the cooling system. Consider all hoses, the reservoir as well as the radiator. If you are not losing it then there is the possibility that your engine is burning it due to a bad head gasket or even a cracked block. Check your spark plug faces and see what they look like. Also heavy white smoking exhaust is indicative of that as well.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 48
Her zaman: 140
