Can cold temperature damage it?
Since there is a special liquid in it, can it be frozen? If so, it won't be damaged? I am afraid, because if i order it, it will be stored in parcel machine, which is located outside where is cold.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
No, it won't damage the iOpener. The iOpener is like an icepack/hotpack.
Bu yanıt yardımcı oldu mu?
@jri_creator is about right. The iOpener contains Glycerol. So let's say iFixit had the glycerol mixed with water at a common 64/36 or a 2:1 solution, the freezing point will be in the -40 deg C (-40deg F :-) region. Even then it will not freeze but turn into a very thick and viscous liquid. Also, there is minimal expansion only, so the risk of rupturing is low. Check it out.....:-)
Ind. Eng. Chem. 1925, 17, 9, 924
Publication Date:September 1, 1925
Extreme temperatures can destroy anything I will comment my real answer on this in a moment
Yes most likely but only VERY cold or warm temperatures
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 27
Her zaman: 473
1 Yorum
@lankerst how cold is cold ;-) ? Excellent Question
oldturkey03 tarafından
