Ana içeriğe geç
The Dell Latitude D820 was released March 28, 2006, identified by model number PP04X.
My computer won't turn on
When I press the power button on the computer, the computer does not turn on, but the control lights next to the power button turn on and blink for a minute and then the computer turns off
LED 1 is lit continuously
LED 2 and 3 are on alternately
Attached is a picture
I would appreciate an answer
Thanks in advance
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi @elchanan1
A blinking caps lock and scroll lock light indicates a motherboard problem (CPU?).
Try removing the ram and start the laptop. If there are no error beeps heard then the motherboard is faulty as ram is checked early on in POST (power on self test) so it hasn't even got that far when starting
Has the laptop been dropped or gotten wet at all?
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
The computer did not fall or get wet
tarafından
@elchanan1
I can only suggest that you download the schematic for the motherboard and check the voltages - see p.47 (CPU voltage) and p.48
tarafından
Yorum Ekle
Have you tried another outlet? Or cable?
Puan 0
6 Yorum:
I tried another cable and it didn't help
The same fault remained
tarafından
There may be a power failure. It may be the motherboard or battery, both, or something else.
tarafından
Could also be a corrupted OS.
tarafından
I tried turning on the computer only when it is plugged in without a battery and still the same error remains
And it's not an operating system because the bios still doesn't come up
tarafından
Have you tried to check the power button? It may be a problem with the case's power button
tarafından
1 tane daha yorum göster
Yorum Ekle
My first thoughts:
https://www.dell.com/support/kbdoc/en-us...
Have you tried reseating the ram and swapping out modules one at a time?
Bad ram is so often the culprit.
Removing one module at a time, trying only one module, and then swapping them around after reseating them
might fix the issue or at least change your LED indicators.
Have you checked all your internal component connections yet (hdd, videocard, modem, CPU, ODD, etc.)?
It's remotely possible you might need to replace the cooling paste on your CPU after so many years.
If it's cheap and easy, I would replace the BIOS battery just for good measure.
Good luck!
Puan 0
1 Yorum:
I already tried everything except thermal paste, but thermal paste should not cause such a malfunction
tarafından
Yorum Ekle
Yanıtını ekle
Elchanan Blumenfeld sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 20
Her zaman: 192
