Ana içeriğe geç
The Xiaomi Redmi Note 10S is a mid-range smartphone by Xiaomi released March 2021. It has a 6.43" AMOLED display, a 64 MP main camera, a side-mounted fingerprint sensor, a 5000 mAh battery, and runs on a Mediatek Helio G95.
Wifi doesn't connect automatically!
When I press the wifi icon it doesn't work until i go to wifi settings and keep refreshing the page! I've struggled with this problem although i updated the phone whenever an update is available
Bu iyi bir soru mu?
Puan 0
2 Yorum
Hi @otamendy99,
Does activating the WiFi work OK if you start and use the phone in safe mode?
tarafından
@jayeff wow i just tried and it works fine but what should i do to make it good in normal mode?? help
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi @otamendy99
If it works OK in safe mode but not in normal mode then usually a downloaded app is the cause of the problem.
A downloaded app is one that you downloaded and installed on the phone and wasn't pre-installed on the phone when you first got it.
You will need to uninstall each downloaded app one by one, and test the phone in normal mode between each uninstall to find out if the WiFi activates OK or not. When it does then the last downloaded app that was uninstalled was the culprit.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Otmnndy sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 10
Her zaman: 155
