How to replace the rear assembly.
I need to replace the rear assembly and the screen on my Pixel 8 Pro. The Screen replacement tutorial is there, but the rear assembly replacement tutorial is not. Is there ANY guidance?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
The back panel is what all the components screw into. The best thing to do would be to follow the teardown and put all components back into a new frame.
Bu yanıt yardımcı oldu mu?
The teardown didn't match the device. The backplate includes the thermal sensor. The battery removal strip is useless, use a thin plastic card (I used the iFixit guitar pick tools and then a hotel room key)
The screen replacement arrived with both an adhesive template to lay the adhesive onto the backplate and ALSO adhesives premounted to the back of the screen. Not sure if one should use both or just one.... 🤣
it sure does SUCK that not only does google not make & sell the replacement nfc flex cable like its available $15 for pixel 7 pro but they made a whole back glass assembly with the nfc n wireless charging flex cable attached for $172 but still no instructional video can be found ANYWHERE ONLINE as far as i can tell so far
7sell
Son 24 Saat: 3
Son 7 gün: 9
Son 30 gün: 44
Her zaman: 1,891
