Ana içeriğe geç
Samsung Galaxy A20, Nisan 2019'da piyasaya sürülmüştür. 6,4 inçlik bir ekrana ve arkasında çift kameraya sahiptir.
How to fix fingerprint
Fingerprint sensor not working
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan -1
1 Yorum:
If I say, "Car not running" can you tell me how to fix it?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
@arisharishraj it would help if you can tell us what you all have already tried to fix this. You have to determine if this is software or hardware related. A couple of common things to do, is to do a soft reset first. Then check for any software updates. Make sure you have the latest software for your phone. So go to your phone's settings menu, then look for the "software update" or "system update" option. If there is an update, download and install it. Next clear the cache and data of the fingerprint scanner app. You should also remove and then add your fingerprints once more. For more on this, check Samsung's directions on here
If none of this worked, this could be a hardware issue and consider replacing the fingerprint scanner. Since iFixit does not yet have a guide for that, use something like this one Replacement sensors for your phone are readily available at many online stores. Pick a vendor that meets your expectations.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Arish Arishraj sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 16
Her zaman: 196
