Ana içeriğe geç
PlayStation 3 (veya daha sık bilinen adıyla PS3), Sony Computer Entertainment tarafından üretilen üçüncü ev bilgisayar eğlence sistemidir ve PlayStation 2'nin akabinde devamı olarak üretilmiştir. 11 Kasım 2006'da piyasaya sürüldü.
My ps3 wont launch apps or games it gets stuck on a black screen
What I already tried :
Changing the cmos battery Changing the thermal paste
Deep cleaning the ps3
Changing the hard drive
Rebuilding system data
Is it maybe because the disc drive wont take disks but I don't think that is the problem because i never use it
What do you suggest?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
Try resetting the video signal. Press and hold the power until it shuts off. Press and hold it again until you hear two beeps. Im guessing you have tried different HDMI cables and another display. If the resolution that the previous owner has set doesn't work with your TV it will do this.
Bu yanıt yardımcı oldu mu?
Puan 0
3 Yorum:
It sadly didn’t work
tarafından
@adamkorkorki at this point if it didn’t work after you tried all that, just take it to a good repair shop
tarafından
https://youtube.com/shorts/JJrdyuDBJ9I?s...
I just posted a video that may help
tarafından
Yorum Ekle
im positive its disk drive problem try to change it and all apps will works fine
Puan 0
Yorum Ekle
If yours is a CECHA,B or a C model. The RSX processor is known to come loose on different spots on its mount (Sauder points) of the motherboard causing a black screen. If this has happened there is nothing more that can be done other than to Reball the processor. Reball not "reflowed" with the heat gun like most people have been known to do. The processor has to be taken off of the board and the balls on back of the RSX have to be stripped off and replaced. I would advise against what people have been showing on sights as a "reflow" with a heat gun as that tactic will warp your motherboard. Reflow done the right way and lasting way requires the right equipment called a reflow machine.
Puan 0
Yorum Ekle
Yanıtını ekle
Adam Korkorki sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 29
Son 30 gün: 121
Her zaman: 1,228
