Ana içeriğe geç
Is this a capacitor issue?
When I first received this iMac G5 17” 2.0GHz 2GB 10.5.8 it would only boot to a black screen. When the power button was pressed you could hear the chime and see the front led light up but the computer would hang at that point. There was no second chime while attempting to reset the PRAM, there was no Target Mode booting and no booting from any external medias. After removing the rear cover I notice that only the first two LEDs would light up when attempting to boot up. After removing the top stick of ram the computer would now boot to the spinning gear and hang there; and this one stick of ram only works in the bottom slot. However, both of the 1GB ram sticks worked just fine in a G5 tower. I then removed a 512MB stick from the G5 tower and installed it in the iMac. I also removed and repaired the iMacs hard drive in the G5 tower. After re-installing the hard drive with the 512 ram the iMac booted up for about 5 minutes before the kernal panic symbol appeared. I then cleaned and vacuumed the entire insides, downloaded a temperature monitoring software and restarted the iMac. And this time the iMac ran for about 15-20 minutes or until the hard drive reached 43 degrees and CPU about 73 degrees before the kernal panic.
After further reading on this site I then checked the capacitors on the logic board and found that the top three capacitors next to the G5 vent are starting to bulge and leak. My question is: How likely are these bulging capacitors the source of my over heating and kernel panic? They really do not look that bad.
Update
pollytintop, thanks for response; and after your advice and a little further reading I have decided to replace the capacitors. If this does not work then I will look into reflow, again thanks.
Update
Pollytintop, thanks for insisting that I continue with the cap replacements because, BINGO it worked. I really had very little faith that this would yield anything positive. Again thanks.
Ps. I am not sure what the normal operating temps are for an iMac but they still seem little high, oh well.
Bu iyi bir soru mu?
Puan -1
1 Yorum
you're welcome Joe. I'm still messing around with a G5 and am by no means an expert on this, let us know how you get on.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
if they are bulging they need to go, if they haven't failed already they are about to. You wouldn't trust a bulging/leaking battery would you? apart from bad caps these machines also have ?CPU solder problems...I replaced my 20+caps and still only get 2 lights, asked guru on here who suggests reflowing..
Bu yanıt yardımcı oldu mu?
Puan 4
Yorum Ekle
Yanıtını ekle
Joe Gordon sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 8
Her zaman: 1,329
