Ana içeriğe geç
Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
Is dvd drive working?
Suppose i unmount the DVDdrive from the iMacs shell case, will i be able to see if its still working? Could i perhaps connect it to some enclosure, or even better (less cost) using some appropriate wiring?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Let’s back up here… if your DVD drive is having problems how about telling what is happening or not happening.
As to your direct question the optical drive is replaceable which if it’s bad. Finding a case to hold it externally shouldn’t be needed if you are just testing it. This is all you need SATA Optical Drive USB Cable
Many people take out the optical drive so they can add in a second drive HDD or SSD. Here’s the needed carrier to do that iMac & Mac mini Dual Drive Enclosure
Increase the storage space in your computer by replacing the optical drive with a second SATA hard drive or SSD. Görseli
Ürün
$19.99
Connect an optical drive to your computer via USB with this part. Görseli
Ürün
$19.99
Bu yanıt yardımcı oldu mu?
Puan 1
6 Yorum:
Thanks Dan, very correct way to answer, but truth is that i want to dismantle my good old 2010 iMac (grfx card broken for the 2time) in order to start selling the parts. Unless u have a better idea :-)
tarafından
@genik - This is such an old system, not sure you’ll get many takers for just for the parts.
Given the state of the graphics logic needing repairs how about converting it to a dedicated display? I’m sure you can use a second display.
tarafından
I’ve already purchased a cheap controller board for turning it to a standalone display, but I’m not really happy with the brightness… it’s not like the original.
tarafından
@genik - Is the kit driving the backlight or are you still using the iMac LED driver board?
tarafından
No iam not using the iMac LED, im using the one from the kit
Are there other kits that make use of the Mac LED drv board?
tarafından
1 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
genik sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 16
Her zaman: 186
