Ana içeriğe geç
6.1 megapixels, ISO 200-1600, DX format, 1.5x field of view crop
Screw stripped - Replacing the CF Reader
One of the side screws is stripped. Is there anything I can do to get it out?
I am thinking of grabbing some tacky glue or something to make it easy to unscrew ( fill the void that was created ). I am open to suggestions and help.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@ilabbe the most common reasons why those strip is because they are to tight. You will need more torque to get it out. I have never had any luck with the "home remedies. I use a rotary tool (Dremel) and a drill just slightly larger than the threaded part of the screw. The center punch the screw head and start drilling the old screw out. Sometimes it's enough to just drill the screw head off and then later (after you disassembled the case) to use a pair of pliers to remove the rest of the screw. All it takes is a bit of patience and not to drill to deep etc. Haste makes waste :-)
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
Haste makes lots of waste!
Thanks!!
tarafından
Yorum Ekle
Yanıtını ekle
Jonathan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 131
