Ana içeriğe geç
The Canon Powershot A590 IS is an 8 megapixel digital point-and-shoot camera with a 4x optical zoom and a 2.5 inch LCD screen.
How is the battery hatch door replaced?
The flip door over the batteries and memory has been damaged. I have a new door, but it came with no directions. I need to know how to remove the old door and install the new door.
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
The door is held to the front assembly via a small round pin. you will have to use a very small pindriver (a small nail might just work too) and some needle nose pliers to remove it. Watch the small spring that is in the middle of the hinge. A bit tedious and it does require some good eyesight and dexterity. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
It does not appear to be enough room to use the pin driver.
tarafından
Yorum Ekle
Yanıtını ekle
Sherri C sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 2,181
