Ana içeriğe geç
Repair and disassembly information for Samsung's Galaxy A32 5G Android smartphone, released in February of 2021.
Deniz den çıktı kapalıydı
Sahilde yürüyüş yaparken kıyıya çıkmış bir Samsung a32 buldum ekranı sağlam ama kapalı haldeydi hiç uyanmıyor şarj olmuyor söküp kontrol ettiğimde ise bir kaç ufak su hasarı tespit ettim acaba düzelir mi?
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
@durumahobulut
The very first step I would take is to disassemble your phone. Use the iFixit guides Samsung Galaxy A32 5G as well as the guides from here to help you disassemble your phone. Remove the main board and the charging board. You will have to remove all the EMI shields. If you do not remove the shields, you are not cleaning the board.
Take a careful and close look at all components and connectors. Truly assess the damage. Look for major corrosion, evaluate the pins in the connectors etc,. Take a look at all connectors as well as cable ends. . Once you got any gross contamination cleaned, use 90%+ isopropyl alcohol and clean your parts some more. For a proper cleaning, use this guide. It was written for an Apple iPhone 3G but all the steps are still pertinent to your phone as well. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning.
Do not use compressed air for the cleaning since that can drive liquid as well as corrosion particles into areas that will cause trouble later on. Do not use drinking water, if you need to use water, use sterile water. Also, you do not need to leave it to dry for a day. Isopropyl alcohol in the higher concentration will evaporate quickly and dissipate the water.
The importance here is the cleaning. It would of course be best to get it ultrasonically cleaned Do not forget to replace the battery. This is a must and not an option. It will fail if you do not take care of it now.
After that, reassemble your phone and re-evaluate. For as long as you have not cleaned your board and replaced the battery, everything is just a guess. Keep in mind that water damage is the hardest to troubleshoot and to repair. It does not matter if is was exposed for 2 seconds or 2 hours, what matters is where the water (particulates) did the damage. Since you did found it on a beach, I suppose we are talking about salt water. That makes it tougher since that is caustic and causes corrosion quickly. Do a really good cleaning and let us know what happens.
Translation
@durumahobulut
Atacağım ilk adım telefonunuzu sökmek olacaktır. Telefonunuzu sökmenize yardımcı olması için iFixit kılavuzlarını Samsung Galaxy A32 5G ve kılavuzları buradan kullanın. Ana kartı ve şarj kartını çıkarın. Tüm EMI kalkanlarını çıkarmanız gerekecektir. Eğer kalkanları çıkarmazsanız, kartı temizlememiş olursunuz.
Tüm bileşenlere ve konektörlere dikkatli ve yakından bakın. Hasarı gerçekten değerlendirin. Büyük korozyon olup olmadığına bakın, konektörlerdeki pimleri değerlendirin vs. Kablo uçlarının yanı sıra tüm konektörlere de bakın. . Her türlü kaba kirliliği temizledikten sonra, %90+ izopropil alkol kullanın ve parçalarınızı biraz daha temizleyin. Düzgün bir temizlik için [kılavuz|5825|bu kılavuzu kullanın] Apple iPhone 3G için yazılmıştır ancak tüm adımlar sizin telefonunuz için de geçerlidir. İyi bir temizliğin önemini ne kadar vurgulasam azdır, bu yüzden her temizlikten sonra alkolü değiştirirken bunu tekrar tekrar yapın.
Temizlik için basınçlı hava kullanmayın çünkü bu, sıvının yanı sıra korozyon parçacıklarını da daha sonra sorun yaratacak alanlara sürükleyebilir. İçme suyu kullanmayın, su kullanmanız gerekiyorsa steril su kullanın. Ayrıca, bir gün boyunca kurumaya bırakmanıza gerek yoktur. Yüksek konsantrasyondaki izopropil alkol hızla buharlaşacak ve suyu dağıtacaktır.
Burada önemli olan temizliktir. Elbette en iyisi ultrasonik olarak temizletmek olacaktır Pili değiştirmeyi unutmayın. Bu bir zorunluluktur ve bir seçenek değildir. Eğer şimdi ilgilenmezseniz arızalanacaktır.
Bundan sonra, telefonunuzu yeniden monte edin ve yeniden değerlendirin. Kartınızı temizlemediğiniz ve pili değiştirmediğiniz sürece, her şey sadece bir tahminden ibarettir. Su hasarının giderilmesi ve onarılması en zor hasar olduğunu unutmayın. Suya 2 saniye ya da 2 saat maruz kalmış olması önemli değildir, önemli olan suyun (partiküllerin) hasarı nerede yaptığıdır. Bir plajda bulduğunuza göre, sanırım tuzlu sudan bahsediyoruz. Tuzlu su yakıcı olduğundan ve hızlı bir şekilde korozyona neden olduğundan işi daha da zorlaştırır. Gerçekten iyi bir temizlik yapın ve ne olduğunu bize bildirin.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Duru maho Bulut sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 50
