Ana içeriğe geç
Game Boy, 21 Nisan 1989'da Japonya'da, ardından 31 Temmuz 1989'da Kuzey Amerika'da ve son olarak 28 Eylül 1990'da Avrupa'da piyasaya sürüldü. Büyük gri kasası ve DMG-01 model numarasıyla tanınır.
Gameboy screen stuck on case
So I opened up my GameBoy and when removing the board with the screen I pried it loose with the plastic tool I bought.
However, unlike any tutorial, the screen remains stuck to the casing instead of coming out together with the board? I re-inserted the screen ribbon and device powered on perfectly, then I removed the batteries and tried again to get the screen out. After the second try failed as well I tried turning the device on but nothing is happening? Please help
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
@ezekiel9898 unless you are the original owner and know what repairs have been done on this, it could be tricky. There is always a chance that somebody got wild with same crazy glue or similar. Get some high grade isopropyl alcohol 95%+ and a syringe. Then inject some of the alcohol between the case and the frame of the display. See if that softens things up. Bottom line here is that you may potentially lose the display since it may crack.
Post some pictures of what this all looks like so we may come up with more "ideas" on how to help you with that. Mevcut bir soruya görsel ekleme
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Ezekiel sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 15
Her zaman: 280
