Ana içeriğe geç
A more affordable, purely handheld version of the Nintendo Switch game console, with integrated Joy-Con controllers and a slightly smaller screen. Released September 20, 2019.
How do I remove stripped screws?
I've removed the back plate of the Nintendo although there are stripped screws on the metal shield plate and I've looked everywhere for a video explaining how to remove I've found nothing.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
The iFixit Store has a couple of products that might help with your stripped screws.
Screw Extracting Pliers: Damaged Fastener Remover
Precision Screw Extractor Set: Small Stripped Screw Remover
If stripping screws keeps happening to you, I'd suggest you invest in a better screwdriver. A properly fitting screwdriver should not strip the screws in a Nintendo Switch Lite.
Four different sized extractor tools to help remove fasteners or screws with stripped heads. Driver head is claw shaped for maximum grip. Sizes range from 1.1mm to 2.0mm. Görseli
Ürün
$24.99
Pliers designed to firmly grip the heads of damaged screws. Specially designed jaws firmly grip screw heads, bolts, or nuts allowing you to twist out even the most damaged fasteners. Professional Grade tool. ESD-safe option. Görseli
Ürün
$23.95
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Try using a bendable object (ETC: WOOL, Wood) on the screw then use a screwdriver to remove the screws or alternatively you can use pliers
Puan 0
2 Yorum:
@ihave0idea, I'm not clear on what you mean when you say "use a bendable object on the screw". Can you elaborate on how that works?
tarafından
@dadibrokeit, When i meant a bendable object, i meant an object that is flexible that can be used on the stripped screw head to make it easier to screw out with the screwdriver
tarafından
Yorum Ekle
Yanıtını ekle
reaper reaper sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 331
