Ana içeriğe geç
Nintendo tarafından Switch sistemi için üretilen, kablosuz ve daha geleneksel bir video oyunu kontrolcüsü. Model numarası: HAC-013.
Intermitent disconnection after battery replacement
Hi!
Last month I started having problems with my Switch Pro Controller. After a while without playing I couldn't get it to charge properly and at the end it stopped charging at all. I checked the battery and it was swollen so I order a replacement and change it as soon as possible.
However, after replacing the battery the controller has started to turn off intermittently. Sometimes just clicking any button turns it on but sometimes it takes it a while to work again.
Is the battery defective? Or it may be caused by an additional problem that needs a different fix?
Please let me know if you need aditional info about it adn thank you all in advance!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I would start by looking at the battery contact, check that no acid or other contaminates are causing your problems. If your problem persists then maybe try disconnecting and re-pair it to the switch
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
I have cleaned both battery contact an device contact without success. Also repairing but it isn't a sync problem, the controller turns off. Is there a way to check if the problem is coming from a faulty battery or some part of the controller?
tarafından
Yorum Ekle
Yanıtını ekle
Rodrigo sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 13
Her zaman: 320
