Liquid got on the Motherboard of MacBook Pro (16-inch, 2023)
The computer worked for one day and stopped turning on.
The charge indicator does not light up when the charging cable is connected.
What if it is possible to revive him after this?
There was some liquid and traces of electrolysis on the motherboard:
Everything was dry under the lid and on the back side:
After cleaning:
Please tell me what can be done with this motherboard to revive the computer, if at all there is a chance?
I checked the battery today and it is completely discharged. And when connected it does not charge. It turns out that the computer turned off when the battery ran out.
There is 0 volt on these contacts (MagSafe). Shouldn't it be 3v by default and 16,5 under load?
The charging unit is working, I tested it on an old MacBook Pro 2019.
Need I try to buy a new charging cable?
Or try to charge the battery directly from the charging unit and check the functionality of the board on a charged battery?
Bu iyi bir soru mu?
1 Yorum
You can also power your system using the USB-C connections too!
Dan tarafından
