Doesn't display anything after turning on
Black screen after turning and displaying logo
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hi @tsionerstu,
Try starting the laptop in safe mode and check if you get a display OK.
If that works it may be a problem with the discrete Nvidia GPU on the motherboard. Either the drivers are faulty or the GPU is.
Bu yanıt yardımcı oldu mu?
@tsionerstu you also need to go ahead and check the backlight. See if that comes on. A simple check for that would be to darken the room and turn the computer on. Then use a flashlight and angle the light at the screen on different areas. you might make out some shapes and shadows that correspond to the startup screen of your OS.
Next connect an external monitor to your Lenovo and see if that displays properly. If so then the issue could be your display, display cable or the display connector.
If the external display does not show anything either, it could be your GPU or your system BIOS.
Here is the Ideapad 5 Maintenance Manual which will help you to work on your computer.
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 35
