gear shifting not smooth got stuck every time I change gear
Problem in shifting gears
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Assuming your vehicle has a hydraulic clutch system then your problem sounds like it is most likely either low of fluid, out of adjustment due to normal wear, broken or collapsed line from the clutch master cylinder to the slave cylinder, or one or both of the before mentioned cylinders has gone bad.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 3
Son 7 gün: 14
Son 30 gün: 35
Her zaman: 566
