Ana içeriğe geç
Bose Soundlink Bluetooth Mobile Speaker II was originally released in September 2012 as an upgrade from the original device. It has an effective range of 30 feet and a battery life of up to 8 hours.
Bosé Soundlink Mobile Speaker Flashing Red Battery
Picked up this speaker at a consignment store and when plugged in it flashes a red battery and does nothing more. It did not come with a charger, however It calls for a 17-20v 1A adapter and I am using a Bose adapter from a sound bar that is 20v 1.9A.
Help!
Thx!
-M
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
@mfirestar the very first thing I would do is to replace the battery. It is most likely no longer holding/accepting a charge. Once you have a new battery installed, re-evaluate. If nothing else, you will at least have a known-well place to start further troubleshooting
Bose Soundlink II Battery Replacement and you can get the battey from here Bose Soundlink, Soundlink II, Soundlink III, SoundTouch 20 Battery
Your power supply is okay to use on it. For as long as the polarity matches.
Replace a 404600, 330107, 330105, 359498, 359495, 404900 battery compatible with Bose Soundlink, Soundlink 2, Soundlink 3, SoundTouch 20 Bluetooth speakers. #CS-BSE107SL. Part #: 330107, 359495, 359498. 11.1 Volts (V). 2200 mAh. 24.42 Watt Hours (Wh). Görseli
Ürün
$39.99
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Milo Firestar sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 23
Her zaman: 118
