Ana içeriğe geç
Model A1137 / 1, 2, or 4 GB capacity / black or white plastic front
68 Soru Tümünü görüntüle
Can you install a larger hard drive?
I would like to use my old nano again (my classic was dropped in a puddle and lost for a few months in the snow) but 2gb is not nearly enough. Are there any larger hard drives out there that will fit?
Bu iyi bir soru mu?
Puan -1
3 Yorum
even tough you can with the EXACT memory used, the recall and battery safety issue is more important then a memory add-on, you don't want it to explode in your pocket
tarafından
and you need to be able to solder WELL
tarafından
I had a 2gig 1st gen. Nano and got an 8 gig unit in the bad batt exchange program.
While I prefer the shape & size of the older Nano, it's nice getting 6gigs more storage for free!
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
This iPod is recalled, get it replaced
http://www.apple.com/support/ipodnano_re...
If it was not, you could not unless you could solder well and get the exact memory for it
it's not a fiesable project, with the recall, get the iPod replaced with the link
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Matthew Johnson,it is not possible. The Nano does not use hard drive. It stores all the information to a NAND memory IC that is an integrated part of the logic board.
Puan 0
Yorum Ekle
some of this information is wrong, the memory is not directly soldered to the board but instead the memory chips are part of some sort of IC module that can be easily removed. i expect it would be possible to exchange the memory between two of these ipods. i wonder however if i could switch with a larger chip into my 2gb
Puan -1
2 Yorum:
Richard Felten, tell us more about "instead the memory chips are part of some sort of IC module that can be easily removed." I would really like to see that module.....I think you got some bad information about this somewhere.
tarafından
Here's a good image of the logic board and the soldered on flash chips (two larger chips) Nano logic bd
tarafından
Yorum Ekle
Yanıtını ekle
Matthew Johnson sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 8,488
