Ana içeriğe geç
A wireless, more traditional, video game controller produced by Nintendo for the Switch system. Model number: HAC-013.
None of my triggers are working.
I have tested all the traces that connect to the trigger assembly and confirmed that they have connectivity. I have cleaned the flex cable multiple times. I have also ordered a replacement part and the same problem still resides. There are no other issues with the controller. Any ideas as to what could be wrong?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
I have had this happen with my Nintendo Switch Pro controllers before as well. The first step is to take the back plate of the controller off, open it up, and carefully lift the triggers and rubber pads up. If you see any debris, or corrosion, use some isopropyl alcohol on a q-tip to gently wipe it off of the contact. If this still doesn't work, you may need to get a new controller, unless you're willing to replace the internal board.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
jack sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 3
Son 30 gün: 18
Her zaman: 559
