Ana içeriğe geç
Pocophone F1, 22 Ağustos 2018'de Hindistan, Yeni Delhi'de açıklanan Xiaomi şirketi tarafından üretilen orta seviye bir akıllı telefondur.
Telefonum kapandi, artik sarj isiğida yanmıyor
Pocofone f1 telefonum, kapandi, artik acilmiyor. Daha once boyle birsey oldugunda sim karti ve hafiza kartini cikartip sarja biraktim. Sarj isigi yandi bi sure sarjda bekledi, sonrasinda acmaya calistigimda acildi. Fakat simdi hicbir tepkime vermiyor, sarj da olmuyor sanirim , sarj isigida yanmiyor, ekran gelmiyor , telefonum acilmiyor
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
@ademcetin sounds like a power issue. First you want to check your charger. Make sure it has the proper voltages. Check to make sure that the pin inside the connectors are not bend etc. After that, check the charging port. Make sure there is no corrosion, debris etc. that prevents it from working. Clean it of any debris etc, use a few puffs of air to clean it out. If all of that checks out okay, you will need to open your phone to see if your motherboard gets power.
Your phone has a sub_board (daughter board) that has teh charging port soldered to it. Check that board for any obvious damage. You can also check the power on the board side while you connect your charger. That way you can test the charging port. Ultimately, I suggest that you replace that board. It is the most common power issue with your phone. Since iFixit does not yet have a guide for this, use the one from here It is written in Spanish but your browser can translate it. You also need to check the flex cables that connect the charging board with the main board. Make sure that there are no rips or tears and that is is properly connected. Last, you want to replace the battery as well. Use this guide for that. Both replacement parts are readily available at many online stores. Select one that you favor.
Translation
@ademcetin bir güç sorunu gibi görünüyor. Öncelikle şarj cihazınızı kontrol etmek istersiniz. Uygun voltajlara sahip olduğundan emin olun. Konektörlerin içindeki pimin bükülmediğinden vb. emin olmak için kontrol edin. Bundan sonra, şarj portunu kontrol edin. Çalışmasını engelleyen korozyon, döküntü vb. olmadığından emin olun. Herhangi bir kalıntı vb. varsa temizleyin, temizlemek için birkaç nefes hava kullanın. Tüm bunlar tamamsa, anakartınızın güç alıp almadığını görmek için telefonunuzu açmanız gerekecektir.
Telefonunuzda şarj portunun lehimlendiği bir alt kart (kız kart) vardır. Bu kartta belirgin bir hasar olup olmadığını kontrol edin. Şarj cihazınızı bağlarken kart tarafındaki gücü de kontrol edebilirsiniz. Bu şekilde şarj portunu test edebilirsiniz. Nihayetinde, bu kartı değiştirmenizi öneririm. Telefonunuzdaki en yaygın güç sorunu budur. iFixit'in henüz bunun için bir kılavuzu olmadığından, şu kılavuzu kullanın buradan İspanyolca yazılmış ancak tarayıcınız çevirebilir. Şarj kartını ana karta bağlayan esnek kabloları da kontrol etmeniz gerekir. Yırtık veya kopuk olmadığından ve düzgün bağlandığından emin olun. Son olarak, pili de değiştirmek istiyorsunuz. https://www.nadiemellamagallina.com/en/m... |bu kılavuzu kullanın] bunun için. Her iki yedek parça da birçok çevrimiçi mağazada kolayca bulunabilir. Tercih ettiğiniz birini seçin.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Adem Çetin sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 72
