Ana içeriğe geç
Canon PIXMA MG6660 hepsi bir arada fotoğraf mürekkep püskürtmeli yazıcı için onarım bilgileri.
Where is the WPS button
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
@ericliddell should be in your settings menu. It does not look like your printer has a physical button. Let's assume you are trying to setup a wireless connection. use the instructions from here You can also download the MG6600 series Manual from here It will help you with your setup.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Every printer I've had doesn't use a button, it's always in the network setting. Don't have a demo Canon, but I do it on the HPs from Network>Wireless setup wizard for the screen versions or WPS on some old 2-liner models. My gently used (with a bad imaging drum) monochrome laser uses the app under Network unless you enter it manually or use WPS.
I suspect Canon is similar.
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
Eric Liddell sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 27
Her zaman: 389
