Ana içeriğe geç
Left speaker not working
How fix it
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum
I need instructions on how to replace the cable that connects the two earpieces. With use, the cable that connects to the left earpiece is showing a loose connection and needs to be replaced. The main issue is how to replace the cable and route it to the other side.
tarafından Paylaş
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@tonymak time to open both sides and check the wiring to the side that is not working. Make sure that the speaker wires are still connected. After that check the wire coming from the other side. Check that for continuity and check the solder joints. Make sure the the "springs" from the transducer make contact. To work on it and since iFixit does not yet have a guide for it, use something like this video and this guide JBL Tune 600btnc Değişim Pili Değişimi to at least get into it.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
If the left speaker is not working probably the internal sprints are not connected properly. This youtube video shows how to fix this: https://www.youtube.com/watch?v=jxVqfxQR...
However for me it did not help, but then I discovered that the other side also has a similar set of springs. In my case they didn't look corroded. With a small screwdriver I made the springs a bit longer (the ones at the right side) and lo-and-behold it worked.
See also this video: https://www.youtube.com/watch?v=igRC-jQp...
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
Tony Mak sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 30
Her zaman: 411
