Ana içeriğe geç
Hover-1 Chrome hoverboard, dahili Bluetooth hoparlörlerle birlikte gelir. Bu sayfa, çeşitli HY-CHR modelleri hakkındaki bilgileri içerir.
Strippted screw on a hoverboard
How to fix a stripped screw on hoverboard
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
4 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Yeah, so a trick I've found useful is sticking a rubber band between the screwdriver and the stripped screw. It gives you a bit more grip to turn it. And if that doesn't work, you could try using a slightly bigger screw if there's room in the hole.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
A variety of suggestions in the Restarters wiki at https://wiki.restarters.net/Rescuing_Dam...
Puan 1
Yorum Ekle
Is it stripped at the screw's head where the screwdriver goes? Or is it stripped inside the device where the screw threads are?
Puan 0
2 Yorum:
The head is stripped
tarafından
Thank you for clarifying your screw situation so we can answer
tarafından
Yorum Ekle
@siuuffv depends on the diameter of the screhead. If it is large enough use a drill. Choose a bit that is about 2/4 the size of the dia,etr of the screw head and then gently drill deep enough until the screwhead will separate from the rest of the screw. Then, once you have the case apart, use a pair of pliers to remove the leftover stub. Hardest part is to keep the drill steady and as centered on the screwhead as possible so it does not run off.
Puan 0
Yorum Ekle
Yanıtını ekle
Siuu ffv sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 15
Her zaman: 437
