Ana içeriğe geç
20.2 MP sensörlü Sony'nin RX100 üst seviye kompakt kamerasının ilk nesli için onarım kılavuzları ve destek. Sony Cyber-shot DSC-RX100, Haziran 2012'de piyasaya sürülmüştür.
Dropped camera - not powering on
I dropped the camera without protection on stone floor. A small crack has formed in the plastic on the left side of the camera seen from the screen, and some parts look a little bit skewed but not much. The power isn’t turning on and when I try to charge it, no light is glowing. All mechanical components are operational and the battery looks intact. Any idea what the problem might be and if it is fixable?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
@jacobvedholm this "small crack has formed in the plastic on the left side of the camera seen from the screen, and some parts look a little bit skewed but not much." we would have to seethe damage to evaluate it. If you have no power at all it is possible that you have a couple of torn/loose ribbon cables or worst case scenario; a damaged board. If it comes on but turns off it could be the lens. A lens that does not retract or extended will get the camera to turn off.
Mevcut bir soruya görsel ekleme TO work on your camera you can download the SM from the Documents part on this page Sony Cyber-shot DSC-RX100 level 2 is the disassembly etc. and Level 3 are the schematics etc. Let us know and see what you find out
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Jacob Vedholm sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 59
Her zaman: 1,155
