Why dose my 2006 Camry not starting
I had to replace my timming belt and my alternator but now am getting lights and evrything but my car wont turn over and whrn do try there is no noise at all coming from motor
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Paul, Are you still having this problem? If so, recommend going back to the basics and checking fuel, battery, starter, etc. If no crank, can you still hear the fuel pump turn on when turning the key to ACC? If not, check the fuel pump fuse. If so, check the battery. If all of that is good, check the starter, including if power is going to the starter.
Bu yanıt yardımcı oldu mu?
Are the lights on then probably not batt........if just click no vroom the starter and if it dies every time you turn it off your alternator
.........gl
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 5
Her zaman: 20
Are you sure you didn't mess up with the timing when you changed your belt?
Vertinhol tarafından
yes just took the old one off and put new one straight on
Paul Nicholson tarafından
