screen cover can't close
Top cover detaching so can close
Bu iyi bir soru mu?
Hi @jefftabs
Here's the hardware maintenance manual for the laptop.
Go to p.56 to view the procedure to remove/replace the LCD unit.
This should allow you to find out what the problem is regarding the lid cover coming loose.
If for example it is a faulty cover or hinge perhaps, on p.70 you'll find the part numbers for the various components in the lid.
If you meant the upper case assembly go to p.54. The upper case part numbers are on p.66. Note that the upper case includes the keyboard which is country specific i.e. country code is shown in part's description, if the whole assembly needs replacing etc.
If a part is faulty and needs replacing, search online for the part number only (FRU number) of the required part, to find suppliers that suit you best.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 25
Her zaman: 302
1 Yorum
@jefftabs, We'll need a whole lot more information on the problem if you expect a helpful answer from the forum. Please revise your question to maximize community understanding.
Russell Repairs tarafından
