Ana içeriğe geç
How to change the battery?
Hi,
i Have this model HP Laptop - 14s-fq0010nj
i wanted to replace the battery when i flipped the laptop and removed from the back case all the screws (as i think )
i were not able to remove the back case yet - its like its stuck or there a something inside that holds that case - now im unable to remove the back case
also - i have no idea how the battery look inside - can i just replace the battery if i removed the back case
thank you
wajde
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
@wajdefadool use this manual HP 14s Service Manual to work on your computer. Yes, besides the screws the bottom cover appears to also snap in. Check page 32 of the manual
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Well I will suggest you to check out the following video it might help you in fixing the issue:
https://www.youtube.com/watch?v=vrX_vghe...
Puan 1
Yorum Ekle
Yanıtını ekle
Wajde sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 23
Her zaman: 746
