Ana içeriğe geç
1.8 veya 2 GHz G5 işlemci ve 2 GB'a kadar DDR1 sistem RAM'i
Help! My mac 'Pops' off at switch on!
My white un-web cam iMac takes four attempts to start up, making a 'pop' noise when failing, but then works well although can 'pop off' when woken from a long sleep.
Is it a bad power unit?
Please help!
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Yes, My first guess would be the power supply. Lay it down flat on its screen.. remove the back.. usually if a power supply is "popping" it will have a distinct smell.. also looks for any buldging or swollen capacitors.
Bu yanıt yardımcı oldu mu?
Puan 4
2 Yorum:
tarafından
I'm pretty sure it's the power supply because the original power supply that comes with this model is notorious for failure after long use.
tarafından
Yorum Ekle
Could be, but could also be a bad hard drive, use disk utility to verify your hard disk if that's failing, a failing drive can make popping noises.
Puan 0
Yorum Ekle
Yanıtını ekle
Big Dan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 21
Her zaman: 2,472
