Ana içeriğe geç
Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
Replace broken keycap without the plastic underneath
Hello,
so I have a MacBook Pro from 2014 here, where one key is missing. The button is still working, if I "click" it, however the cap is missing. Thinking, that I only need to get the cap, I bought some caps off of aliexpress, however, I then realized that that white "plastic" underneath is missing... How can I fix that key to have it fully working with a keycap again?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
4 Yorum:
@nameless7069 Apple refers to this as version S keyboard. See if this Keycap Replacment will help you out with the repair
tarafından
@oldturkey03 - OT your page access is forbidden! Is it just a duplication of the BookYard reference I posted in my answer?
tarafından
@danj why would I even want to repost something? I don't want to waste my time reposting stuff since that does not help any OP. Reposts are only useful to either build further on it or for clarification.
@nameless7069 once I know you can access this Key Replacment I will move it back to a comment. Not sure why it gives an error when I place it as a comment. Anyhow, hope it helps.
tarafından
I can indeed access it, thank you, I'll have a look
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Its hard to tell which version of keyboard you have. Apple contracted two different companies to produce them for this system. Review this web page to identify which you have. You may need to pop off one of the other arrow keys to help you Key Caps Click on the image to dig down to the discrete parts.
Bu yanıt yardımcı oldu mu?
Puan 0
5 Yorum:
@danj removed another arrow key and it definetely looks like type k... however, when removing, I realized, that underneath, it's not only that white plastic missing, bt also that "dot" in the middle...
tarafından
@nameless7069 - TheBookYard can supply the rubber cap as well.
tarafından
@danj thank you, ordered another keycap, the plastic scissors and the rubber dome... Hope it works out
tarafından
@danj you don't happen to have a guide on how to insert the rubber dome and scissors, do you? removed one scissor clips and can't get it back in now...
tarafından
@nameless7069 - Sorry, iFixit doesn’t have a guide, I believe TheBookYard folks throw in a installation sheet. If not there are a few YouTube vids you can review.
tarafından
Yorum Ekle
Yanıtını ekle
nameless sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 26
Her zaman: 257
