Ana içeriğe geç
The Theragun Mini is a handheld percussive massage therapy device that is designed to help soothe sore muscles, reduce tension, and improve overall muscle function.
How do I open the Theragun mini?
Something's loose inside and it's really starting to bug me... When I turn it on it sometimes work but mostly it won't turn on. my hypothesis is that piece is jamming the motor. Can someone help me??
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
2 Yorum
did you manage to open the device without breaking it? I can't find the way to do it. If you have any picture or guide that help me, I would highly appreciate it :)
tarafından
@santihp Put it in a vise (gently, use cardboard), then place a heavy duty razor blade along the seam and smack it carefully with a small hammer. You need to break the glue seal- very tight. Working it, you'll eventually get a crack going and you can use screwdrivers to pry it open. The battery pack is daunting, however. Custom circuit board soldered to the top, trying to find a solution...
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Dropped my theragun mini and broke the on/off button, so I had no choice but to crack it open. See photo attached.
Bu yanıt yardımcı oldu mu?
Puan 2
7 Yorum:
How did you crack it open?
tarafından
tarafından
Hey Karl, was your battery pack still working? Can I buy it if you're not going to fix it?
tarafından
My theragun mini has suddenly stopped charging 😩 I have had it since 2019. I would like to fix it myself if f possible🤷🏽‍♀️ I can’t find a video to show how. Please help, I need this thing for my back.
tarafından
Same here 😓😓
tarafından
2 tane daha yorum göster
Yorum Ekle
@aidenc it's a pryjob! Take a quick look at this video to get an idea how it is put together.
While you work on your Theragun, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Puan 1
3 Yorum:
Video link is broken, Did TheraScam force a takedown?
tarafından
@goofpod sure appears that way :-( Seems like another company we all should avoid. Let's see if there is anything similar somewhere. If not, it maybe time to invest in a broken one and to tear it down.
tarafından
I would avoid the company except that their Theragun Mini is a very cool design. Fits nicely in the hand and packs a punch with massage relief. Teardown is a bear- getting those two halves to separate is no fun. But the important second challenge, as I mentioned elsewhere, is the circuit board soldered to the batteries and is very difficult to replicate. I found suitable batteries on eBay but haven’t attempted it yet. It’s on my list of fun things to do next…
tarafından
Yorum Ekle
If you suspect a free piece internal to your Theragun mini is causing it to malfunction, you can open the machine by following these steps: Check the guide for guidance, accumulate the essential tools, hit upon and take away any screws preserving the casing, cautiously open the device, take a look at and do away with any unfastened pieces, and reassemble the machine securely. If unsure, contact the producer or an expert for assistance.
Puan 1
4 Yorum:
Hi i would like a help to have a road map to how to open my theragun 1st generation.
tarafından
@yassineela94556 Put it in a vise (gently, use cardboard), then place a heavy duty razor blade along the seam and smack it carefully with a small hammer. You need to break the glue seal- very tight. Working it, you'll eventually get a crack going and you can use screwdrivers to pry it open. The battery pack is daunting, however. Custom circuit board soldered to the top, trying to find a solution...
tarafından
What if you don’t have a vise to put it in? Mines wont hold a charge
tarafından
It’s extremely difficult to open. Without a vice I don’t think you could hold it securely enough to break the seal with a razor blade using force. The second challenge is the battery pack itself. A small circuit board is soldered to the batteries in a way that is hard to replicate. These devices were clearly not made to be repaired, unfortunately.
tarafından
Yorum Ekle
Yanıtını ekle
Techn0pr0 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 19
Son 7 gün: 94
Son 30 gün: 448
Her zaman: 4,445
