Ana içeriğe geç
The Blendtec Total Blender is an all-in-one blender released in late 2004.
Is this repairable or is it time to move on?
Should I attempt to repair or move on? Also, any suggestions on the Blendtec model I should purchase next?
Picked this one up in 2009/2010 from a neighbor…$150. My family of 8 has been using it ever since. Unreal!!
Recently (over the last 6-8 months) our blendtec started sounding loud-er as if it was metal on metal. I dismantled the entire unit today and discovered the following: (see photos). Assuming the bearings wore out causing the rotor /drive shaft /commutator segments to turn off axis leading to this grinding and the pitted effect? Thoughts? Suggestions? Comments?
Purchased this Blendtec Model: ES3 Serial #: 12222 up 14 years ago from a neighbor. I’m pretty sure it’s gameover for this machine.
Update (03/26/24)
Update (03/26/24) ===
Here are the disassembled parts for reference. It's important to note that dislodging the rotor from the motor base—the part on which the blender jar sits—was challenging due to a snug fit. A hammer and a steel punch were needed to tap it out successfully.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
2 Yorum
@seanallen23447 not sure about game over yet but definitely a chewed up armature :-). What does the stator look like? I suppose it'll be similar :) Just out of curiosity, what happened?
tarafından
@seanallen23447 looks better than I expected :-)
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
@seanallen23447 yep, looks like Game Over for the motor since I envision the rest of it got chewed up too (bearing failure?) Time to keep your eyes open at places like Ebay or even Craigslist (not sure what country you are in) and get a used base. You can either use that or harvest the motor from it.
Bu yanıt yardımcı oldu mu?
Puan 1
6 Yorum:
I’m assuming bearing failure
tarafından
@seanallen23447 these use quite an interesting electrical motor. Universal Motor. "A type of electric motor that can operate on AC or DC power. It is a commutated series-wound motor where the stator's field coils are connected in series with the rotor windings through a commutator. It is often referred to as an AC series motor." Impressive performance and also an impressive cost to replace one of those. I would move on by getting a different base. BTW based on your label this motor was also used in the Blendtec Smoother 13
tarafından
Very impressive!
tarafından
@seanallen23447
You may be able to negotiate a better deal on the following as donors this or this (depending on shipping etc) unless you think that it is too much to pay.
Just an idea
tarafından
I agree with old turkey, find a used one on eBay or Craigslist. I recently replaced the motor brushes on mine. I used it more than once per day for ten years before they wore down. The brushes on yours like to have a lot of life left. You could use your current one for donor parts.
tarafından
1 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Sean Allen sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 18
Son 30 gün: 78
Her zaman: 515
