Ana içeriğe geç
do I need to replace the adhesive?
If I open it up do I need to replace the adhesive?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
1 Yorum
Short answer. Yes.
Longer answer. Depending on where you open it up you may damage the adhesive and it will be safer to replace it than not doing it. Replacing it will also ensure liquid resistance is kept.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I would recommend replacing the adhesive after you open the device up. The adhesive helps ensure dirt, dust, and water doesn't get into the device. Not replacing the adhesive could result in moisture damage, which would end up costing you far more than the relatively small investment.
Google Pixel 8 Screen Adhesive - Genuine
This custom cut adhesive film secures the display panel to the frame of a Google Pixel 8 smartphone. Görseli
Ürün
$3.99
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Grayden Hormes sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 13
Her zaman: 291
