Ana içeriğe geç
Logitech G Pro X Superlight kablosuz oyuncu faresi için onarım ve söküm bilgileri. MR0106 model numarasıyla tanınabilir. Aralık 2020'de piyasaya sürülmüştür.
Why is it not charging?
When ever I plug in my superlight to charge it and take the charger out after a while it shows a red light and turns off a couple seconds later
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I have the same problem but when I plug the charger led is off. My mouse is off I can’t use it , already change the cable but do not match.. can you help me please? 🙏
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
This is usually one of two things,
The charge port, this can easily be ruled out by being able to use the mouse wired.
The battery, it may have degraded for various reasons however if the mouse indicates its charging when plugged in and when unplugged it dies, its most likely the battery is no longer able to hold a charge.
Puan 0
1 Yorum:
What about if when I plug in my GPRO Superlight to charge and it doesn't charge. Like the light on the top won't turn on.
And when i try to plug it into the cord/wire the mouse still won't work.
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
Rian sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 21
Son 30 gün: 93
Her zaman: 5,598
