Ana içeriğe geç
Game Boy, 21 Nisan 1989'da Japonya'da, ardından 31 Temmuz 1989'da Kuzey Amerika'da ve son olarak 28 Eylül 1990'da Avrupa'da piyasaya sürüldü. Büyük gri kasası ve DMG-01 model numarasıyla tanınır.
Game boy not turning on
I found my daughter’s Game Boy packed away in a bin in the basement. It’s been there for at least 15 years since she moved out. I thought my grandkids would like it. I cleaned the battery area and used new batteries but I can’t get it to turn on. The battery light doesn’t even come on. I called Nintendo and they no longer repair them. Any suggestions?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
@lorimaleko27985 the very first thing you want to do is to clean the battery contacts. Make sure they have not corroded to badly. If those are okay, you will have to disassemble your GB and take a look at the components. You could try and clean it with some isopropyl alcohol (+90%) and carefully check to see if there is anything obviously corroded etc. Until you have it apart, anything will only be a guess. Use Game Boy these guides to help you with taking it apart. Once you have it open, take a couple of well focused pictures and post those with your Question. That way we can see what you see and hopefully guide you further. Mevcut bir soruya görsel ekleme
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Thank you. I just ordered a tri-wing screwdriver off Amazon and should receive it in a few days. I’ll let you know how I make out when I have it apart.
tarafından
Yorum Ekle
Yanıtını ekle
Lori Malekovich Pluta sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 14
Her zaman: 230
