Shows black screen and startup sound is heard
Shows black screen and startup sound is heard as if it is ready for setup but nothing shows on screen. When booting, meta logo does show and then 3 dots, then the black screen.
Bu iyi bir soru mu?
Bu iyi bir soru mu?
I understand that you're experiencing a **black screen isssue** with your **Meta Quest 2** during startup. Let's troubleshoot this together! Here are some steps you can try:
1. **Hard reset**:
- Hold down the **power** and **volume down** buttons on your Meta Quest 2 for at least **10 seconds** or until the boot screen appears.
- Use the volume buttons to scroll to **"Boot device"** and select it using the power button².
2. **Factory Reset** (if needed):
- Press and hold the **power** and **volume down** buttons simultaneously until your Quest turns on.
- Navigate to **"Factory reset"** using the volume buttons and press the power button.
- Finally, select **"Yes, erase and factory reset"**³.
3. **Check Graphics Settings**:
- If you're using a hybrid graphics card setup (common in gaming laptops), where some processes run on the dedicated card while others run on integrated graphics, it might cause issues with Oculus Link.
- Try changing all Oculus files to **"High Performance"** in Windows' direct graphics settings instead of using Nvidia's control panel¹.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 263
